I am looking to purchase a BH configuration and am wondering what the difference would be between purchasing a BH setup and just using an AP and SM to make a BH? I’ve never seen the BH software and was wondering is someone could give me a comparison or make a recommendation for me as to the differences. IE latency, half duplex and just overall performance experience. I am looking to make a four mile link.
Non advantage will give you 7 megs aggregate.
Advantage will give you 14 megs aggregate.
I believe latency should be roughly the same.
If you are using it for a true point to point link why would you want to use an AP/SM unless you have it laying around?
See my comments on your previous thread.
