Hi @ll,
we have 6 BHs in a Point-to-Point chain (5.4 GHz 10MBit modules, P9, Firmware 7.1.4 DES) connecting a branch with the headquarter. The RF Link ist used for VoIP and Terminalserver sessions.
We regularly have timing problems with the VoIP phones wo we want activate the High priority queue. Can someone tell me, how to set up this in such a chain?
Thanks in advance.
Ralf Eisele
eXtension World Wide Connections GmbH
Partner der abbex-group.ag
Finninger Strasse 56 Fon: +49 731 9216333
D-89231 Neu-Ulm Fax: +49 731 9216335
Germany Mobile: +49 179 2991333
http://www.extension.net - info@extension.net
PGP Fingerprint: C29E 9EE9 6A36 8EDA 7146 1613 0BA8 9080 5B4A 36A3
How are you performing the syncronization of this long chain? How many CMM’s are you using? Can you explain how the master/slave relationship is throughout the entire chain?
Canopy_Support wrote: How are you performing the syncronization of this long chain? How many CMM's are you using? Can you explain how the master/slave relationship is throughout the entire chain?
Okay, here we are:
Branch
BHS
I
I
I
BHM
I
BHS
I
I
I
BHM
I
----- CMM
I
BHM
I
I
I
BHS
Headquarter
The synchronization is not the problem but the high priority channel or how to configure this respectively.
Can you tell me how to configure it?
Ralf Eisele
