Me_Sanay
(Me Sanay)
#1
Dear all,
I am trying to connect 2 sites with a distance of 60 KM with a pair of ePMP 1000 connectorized (NON-GPS) radios and 34 dBi dishes.
I understand that using a 40 Mhz channel, I can only connect up to 25 KM.
Using a 20 Mhz channel with ePMP 1000 plus 34 dBi dish, I have connected distances up to 40 KM.
What I want to understand is that if there is any limitations on the distance using 20 Mhz channel?
With a clear LOS between the 2 sites with a distance of 60 KM, can I connect the 2 ePMP 1000 radios using a 34 dBI dish on a 20 Mhz channel?
Sanay
Fedor
(Fedor)
#2
Would you like to use ePTP mode for this link?
ePTP mode has next Max Ranges:
40 MHz - 24 rm
20 Mhz - 52 km
5, 10 MHz - 52 km
In TDD or TDD-PTP mode you can establish connection on distance up to 65 km.
You can take a look on other user experience with long-range links here:
http://community.cambiumnetworks.com/t5/ePMP-Stories/bd-p/ePMP_Stories
Thank you.
Me_Sanay
(Me Sanay)
#3
Hi Fedor,
I was thinking about using ePTP for the 60 KM link.
Now that the maximum distance for an ePTP link is only 52 KM, I will use TDD for this 60 KM link.
Thank you for the quck response and clarification.
Regards,
Sanay
