I recently have started to see some interference on some my 6ghz APs. However I cannot identify the type as they are not ePMP 4k equipment and do not show up in the Detailed Interferer table.
The spectral mask does not look like ePMP equipment, and it does not look like Tarana either as their spectral mask looks different as well.
On each AP that I see them they always look the same like in the example photo below. My ePMP 4k are in the blue boxes and this odd interference is in the red box. Looks like two either 20mhz or 30mhz channels with a 20-30mhz separation between them. I see this same mask on another AP but on different frequencies.
As besides Cambium and Tarana I am not aware of any other outdoor PtMP systems could it be a licensed PtP link?
Also it seems to be temporary as when it usually appears it is in morning hours from like 7am to 9am but not daily.
This scan is from an AP where it is not directly interfering with my connections, but on another AP when it appears it is directly on top of my chosen channel.
