00:00:00 UT : Mon Jan 01 2001 : File src/syslog.c : Line 1181 System Reset Exception -- Watchdog Reset
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 417 ******System Startup******
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 422 Software Version : CANOPY 8.2.1 SM-DES
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 426 Software Boot Version : CANOPYBOOT 1.0
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 436 FPGA Version : 092707
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 440 FPGA Features : DES, Sched
10:56:49 UT : Sun Oct 21 2007 : File src/syslog.c : Line 1283 Time set
21:18:41 UT : Sun Oct 21 2007 : File src/osportucos_ii.c : Line 56 calloc1 failed, out of heap, size 184630
21:27:44 UT : Sun Oct 21 2007 : File src/osportucos_ii.c : Line 56 calloc1 failed, out of heap, size 294912
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 109, msg: (null)
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 67, msg: (null)
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 6, msg: (null)
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 75, msg: (null)
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 80, msg: (null)
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 99, msg: (null)
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 69, msg: (null)
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 59, msg: (null)
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 16, msg: (null)
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 8, msg: (null)
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 2246, msg: (null)
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 7, msg: (null)
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 93, msg: (null)
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 117, msg: (null)
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 15, msg: (null)
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 118, msg: (null)
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 127, msg: (null)
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 124, msg: (null)
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 119, msg: (null)
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 121, msg: (null)
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 123, msg: (null)
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 64, msg: (null)
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 21, msg: (null)
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 96, msg: (null)
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 56, msg: (null)
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 20, msg: (null)
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 72, msg: (null)
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 66, msg: (null)
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 70, msg: (null)
21:27:44 UT : Sun Oct 21 2007 : File webportglu.c : Line 99 Error writing to file system. 12, msg: (null)
21:58:06 UT : Sun Oct 21 2007 : File src/osportucos_ii.c : Line 56 calloc1 failed, out of heap, size 120
21:58:06 UT : Sun Oct 21 2007 : File src/sockintf.c : Line 119 FatalError()
21:58:06 UT : Sun Oct 21 2007 : File src/stack_dump.c : Line 143
Stack Dump information:
Current context Task: SOCK
Current Stack: 2%
Max Stack: 19%
Task Stack Dump:
0x00751fa0: 0x00001fa4 0x00752000 0x0079a620 0x0074f4b4
0x00751fb0: 0x00000bff 0x0003000d 0x0071239c 0x0071245c
0x00751fc0: 0x00000000 0x00000000 0x00000000 0x00000000
0x00751fd0: 0x00000d05 0x01200200 0x0000e93d 0x00000000
0x00751fe0: 0x00000000 0x00000000 0x00000000 0x007524b0
0x00751ff0: 0x00000122 0x00000920 0x534f434b 0x00000000
0x00752000: 0x00000000 0x00751fa4 0x00000226 0x00002ffc
0x00752010: 0x0000001d 0x0000006b 0x00000000 0x534f434b
0x00752020: 0x00000000 0x00000021 0x007c329e 0x00190e8c
0x00752030: 0xffffffff 0x0075203c 0x00048f28 0x0011f9ec
0x00752040: 0x00000077 0x00000000 0x00045a0c 0x00000000
0x00752050: 0x00000001 0x0042190c 0x00d88000 0x00045cd0
0x00752060: 0x00000000 0x0075210c 0x00000010 0x00000001
0x00752070: 0x0042190c 0x0042190c 0x00d88000 0x00047bd4
0x00752080: 0x0042190c 0x0075210c 0x00000001 0x00e05d34
0x00752090: 0x00000000 0x00000000 0x00000000 0x00000000
0x007520a0: 0x00000000 0x00000000 0x00000000 0x00000000
0x007520b0: 0x00000000 0x00000000 0x00000000 0x00000000
0x007520c0: 0x00000000 0x00000000 0x00000000 0x00000000
0x007520d0: 0x00000000 0x00000000 0x00000000 0x00000000
0x007520e0: 0x00000000 0x00000000 0x00000000 0x00000000
0x007520f0: 0x00000000 0x00000000 0x00000000 0x00000000
0x00752100: 0x00000000 0x00000000 0x00000000 0x00000010
0x00752110: 0x00000000 0x00000000 0x00000000 0x00000000
0x00752120: 0x00000000 0x00000000 0x00000000 0x00000000
0x00752130: 0x000cddcc 0x00000000 0x0075239c 0x007523f8
0x00752140: 0x00752454 0x00000000 0x00000000 0x00000000
0x00752150: 0x00000000 0x00000000 0x00000000 0x00000000
0x00752160: 0x00000000 0x00000000 0x00177ff8 0x00000000
0x00752170: 0x00000000 0x00000000 0x00000000 0x00000000
0x00752180: 0x00000000 0x00000000 0x00000000 0x00000000
0x00752190: 0x00000000 0x00000000 0x00000000 0x00000000
0x007521a0: 0x00000000 0x00000000 0x00000000 0x00000000
0x007521b0: 0x00000000 0x00000000 0x00000000 0x00000000
0x007521c0: 0x00000000 0x00000000 0x00000000 0x00000000
0x007521d0: 0x00000000 0x00000000 0x00000000 0x00000001
0x007521e0: 0x330eabcd 0x1234e66d 0xdeec0005 0x000b0000
0x007521f0: 0x00000000 0x00000000
Return Addr: 0x0011780c
wow, that will slow me down
LP wrote: wow, that will slow me down :(
if somebody who is familiar with canopy firmware could tell what are osportucos_ii.c and sockintf.c I can try to understand what condition causes the error...
I imagine you have already, but if not- contact canopy tech support on that one. There might be someone that has seen that and I hope so, but I have never seen those errors before. Have you tried reverting to your previous version to see if that problem is then gone. (that’s what I would try/ have had to do in the past). Then you have the problem of wondering if there’s merit to Canopy’s advise of NOT flashing back.
Anyhow, do you have others doing this, or just this one?
LP wrote: I imagine you have already, but if not- contact canopy tech support on that one. There might be someone that has seen that and I hope so, but I have never seen those errors before. Have you tried reverting to your previous version to see if that problem is then gone. (that's what I would try/ have had to do in the past). Then you have the problem of wondering if there's merit to Canopy's advise of NOT flashing back.
Thank you LP, I have a tcket (M-228440) on that one.. still no answer. I guess I have to do the downgrade manually with ftp because CNUT does not allow it anymore.
Hi warian
why coudn't you downgrade using CNUT?
I simply loaded both packages (8.1.5.1 and 8.2.1) on CNUT.
Then, I can temporarely disable 8.2.1 (on packages mangement), so I can downgrade smoothly from 8.2.1 to 8.1.5.1.
Let me know if you can't
Ciao
Massimo
Having the exact same problems on over 200 AP’s at this time…
One error is actually created when CNUT tried to start AutoUpdate (of the SM’s), and the other error, like the OP logged, causes the webgui to hang up… Can only be rebooted via telnet (80% of the time)…
Happens on BOTH 8.2 and 8.2.1, and doesn’t care if it is a 900/2.4/5.2/5.7
As you can imagine, after spending 3 weeks updating to 8.2, then again to 8.2.1 on 4000+ devices, AFTER I got Moto’s blessing, I am not too thrilled…
I have sent all my event logs to support… Will let everyone know if I get a response this year…
Brian
Funny. That ticket number does not exist. Last time I had a problem I sent them an email. 2 hours later I get an email back from them with a ticket number that looked just like that. Next day I called to check on status and they said that ticket number was not one of theirs. They asked me to send the email with the problem again. Never heard back and on top of not acknowledging my problem, the new software release 8.2.1 claims to fix one of the issues I was having :x
How can I checkif the ticket number exists?
ANY word on this? I just saw this happen this morning. The wierd thing I had happen was I could not get to the GUI interface of the BH20 until I physically unplugged it and plugged it back in. then all seems well. Durning this time my ping times would be fine for 3-4 pings (8-12ms) and then for one ping only it would jump to 115+/-. then for 3-4 pings it would be 8-12ms… then again jump to 115+/- it was a pattern. as soon as I rebooted the BH the pings are now steady at 9-10ms.
We have had to send CNUT Gather Support tool dumps on AP’s affected. They (front line) didn’t believe us, and stated the same crap most have you heard - 8.2.1 fixed it… lol
They also completely ignored my email from 2 days ago because I didn’t have a ticket number… Apparently the fact we have almost 500 AP’s and 10000 SM’s means nothing…
Will keep you posted, as I now have a ticket #, and they have more data to make excuses about…
Brian
I have a topic here http://motorola.canopywireless.com/support/community/viewtopic.php?t=4478
it’s called errors on 5.7 link. I have had this problem for two months and have still heard no word. I called them for help or even an update- they said they are really busy, and basically not to hold my breath… :x
We’ll see how it goes.
