Unfortunately, it seems that the 8.2 + NAT problem persists.
I upgraded to 8.2.1 and in few hours the SM crashed twice.
This is my log:
00:00:00 UT : 01/01/01 : File src/root.c : Line 417 System Startup
00:00:00 UT : 01/01/01 : File src/root.c : Line 422 Software Version : CANOPY 8.2.1 SM-DES
00:00:00 UT : 01/01/01 : File src/root.c : Line 426 Software Boot Version : CANOPYBOOT 3.0
00:00:00 UT : 01/01/01 : File src/root.c : Line 436 FPGA Version : 100207
00:00:00 UT : 01/01/01 : File src/root.c : Line 440 FPGA Features : DES, Sched
16:37:25 UT : 10/15/07 : File src/syslog.c : Line 1283 Time set
18:08:33 UT : 10/15/07 : File src/nibuf.c : Line 448
NiGetBuf(): Out of buffers: SrcLUID == 260
Used Bufs: 1384 Total Bufs: 3000 NoBufs: 0
Buffer Allocation:
LUID: 257 Used: 32 Max: 2048 NoBufs: 0
LUID: 258 Used: 1 Max: 3000 NoBufs: 0
LUID: 260 Used: 1351 Max: 1350 NoBufs: 0
I am very disappointedā¦
Anyone still has the same problem?
Ciao
Massimo
Report this to Motorola, please.
I have the same problem with 8.2.1 NAT enable!!!
Motorolaā¦
But, anyone of development team read the technical support case opened or this forum??
And Motorola still stay silent.
Best Regardsā¦
Fabio Marocco
twinkletoes wrote: Report this to Motorola, please.
I already reported to italian motorola distributor.
Hope they will forward to motorola us.
ciao
massimo
Meh. Iām beginning to think Iāll just abandon 8.2.x on anything but APs. 8.1.5.1 never gave me any troubles.
if ur going to use any 8.X use 8.2.1 working pretty good for me its been almost 3 days
8.2 was a disaster for us. We ran 8.1.5.1 on many access points and SMs for almost the entirety of its release with no troubles. Iāll be going back to that until I know for sure that 8.2.1 is safe.
wifiguy wrote: I'll be going back to that until I know for sure that 8.2.1 is safe.
Same to me. If you use SM with NAT enabled you should stay to 8.1.5.1
I just TRASHED my 2.4 system (which has worked great for years) by upgrading it to version 8.2. My customers are pissed and having nothing but problems since. I think I will have to take the system to an earlier version as well!
"IF IT AINāT BROKE, DONāT FIX IT!"
JS
