I am programing up a pair 850C and i am having issues with the first radio hooking up. from the pictures am i doing anything wrong?
Why is the TX level so low? You should have “Adaptive TX power admin” enabled, and you should have the “TX Level” set to the highest value that your license allows. Admin status should be up.
are these on the bench or already in the air?
Check on 176.16.22.41 radio your MRMC scripts are set correctly on both radio cores and not just on 1 radio. Your TX Level power should be higher on both radios as well. (Should have drop down going higher than 10 … whats the highest?)
Scripts are the same and turned up the power with no change. I have set up 850 links before with no issue at lower power on the bench. I have defaulted the radio’s and tried reprograming the link with the same result and double checked my durplexers. Really stumped.
