So I have a 900 connection. It works great when it works. Usually runs -72ish at the SM reading -70 at the AP. RSSI in the 1500’s.
I originally had the SM side connected to a 18dBi Yagi. I thought maybe the beamwidth was too narrow so I switched down to a 9dBi Yagi.
Radio is located about 8 miles out.
Several times a day it completely drops. The SM goes to scanning and can’t pick anything up. Noise floor shows in the -90’s
I’ve tried switching all different channels on the AP also. I have about 6 clients on this AP - none have the issue.
I just turned off color codes tonight.
Any other ideas?
I also just set the SM to come up in operation mode instead of align mode when no link.
The outages usually last anywhere from 30 minute to 2 hours.
I had this problem with an SM recently. I just replaced the SM, problem seems to have disappeared.
No such luck. Replaced the SM today and still have identical problems.
