Does anyone have insight on exact configuration of a 900 connectorized sm with a 13dbi yagi. Having a horrible time getting anything from outside of the footprint that we can service with the non-connectorized sm.
Our tower just has one active connectorized Ap with a 360 cyclone antenae.
the Ap is set to 40 miles, we have tested many different residences in every direction at 4, 6, 10 miles and can’t get anything. I have set the sm to 36-13=23dbm which is the proper configuration. It just doesn’t make sence that we can’t get anything, the yagi works great where we have clients online with non-connectorized.
Could closer sm’s that are still at default dbm be cause desensitization of the AP so the futher sm’s won’t get connectivity. Any thoughts would be much appreciated.
You indicate that the integrated 900’s work fine, but connectorized with yagi’s do not work? The gain of an integrated is 12.5dB, only .5dB higher than the integrated. The actual power to the antenna is about the same through the connector. What you gain with 13dB Yagi is slightly narrower dispersion.
With that said, the ONLY thing I can think of is polarization. The yagis ship for vertical polarization. You have to remove the bracket and rotate the antenna so that the elements are horizontal (i assume the omni is horizontal since the integrated work fine.)
Make sure you are not touching the antenna forward of the back elements when doing a survey.
While the problem you describe is likely polarization, you mention power levels. You want to set the SM’s so that their power at the AP is -75 to -65. If you have an unusually high background RF level, then raise your window so that the lower limit is 10dB above the noise floor. If you have 4-5 SM’s with -45dB at the AP you are in fact desensitizing the AP.
I talked to a local competitor and they dont install the customer enless the power lever is -75dbm or stronger! Shoot, 79 looks good to us… no wonder they drop all the time. :oops:
So if I turn down the radios that are closest, and there are a half dozen at 24dbm all about a mile from the tower to about 10 to 13 dbm it should make things a little quieter, so the sm’s 6 to 10 miles will have a better chance to see the ap and register on the network.
The yagis are a mystery, i am wondering if the 13dbi are too strong for the area 6 miles away because when my techs couldn’t see anything with the 13dbi the 10dbi saw the network but the signal still wasn’t as good as the original non-connectorized that was in place. This is definately a frustrating experience for us.
Wireless. -79 would be OK if the noise floor was below -90 which is not likely. You can deal with this by using a higher gain antenna on the SM.
Sinned, yes turn down the closer SM’s. Start lowering the SM’s power level 2-3dB at a time until the AP sees the SM between -75 and -65. Don’t drop too low too fast. If the level drops too low, the SM won’t register and you will be rolling a truck. This will improve the performance of your remote SM’s. We have SM’s as close as 2 miles and as far as 15miles on the same AP.
A 13dBi would not be too strong at 6 miles, that would fall in around -60dB which is a little strong, but not a problem.
Are you sure you have 900MHz yagis? This is sounding like you might have 2.4GHz yagis. Otherwise I think you got a batch of bad antennas.
Thanks Jerry, i am personally going onsite tomorrow to test the gear. You may be right and the antennas may be a bad batch, I hope not though. This is delaying our deployment to many excited customers. Thanks for the advice on the closer sm’s too. Much appreciated.
Can anyone tell me if there would be a difference in connectivity and signal reception between a 13bdi yagi from pacific wireless at 100 watts and a cushcraft 200watt 13dbi yagi. We were supposed to get the cushcraft but our supplier decided to get the pacific wireless yagi instead because of delivery time and cost. But they are not working for us at all. Very poor signal, if any, at various location in our 4- 10 mile test footprint. Should we go with the cushcraft? I told my supplier to go with the best quality and not to worry about price point. We are not very impressed with these at all. We followed the dbm setup for the yagi’s 36-13=23dbm in the sm. Tried different sm’s and yagi’s and for the most had nothing. Where i have customers 8 KM away connected with a non-connectorized sm, I had very poor signal with the 10 and 13 dbi yagi on the exact same roof as the non-connectorized. Has anyone used these in rural areas with nlos/los and had the same issues?
As long as you are orienting the yagi properly (horizontal) and are not touching the element while testing then it whould work fine.
We use the Cushcraft with very good perfromance. I think you got a bad batch. Obviously this can be confirmed by getting a cushcraft and testing with that.
I am picking up the cushcraft yagi’s today…thanks. Just curious Jerry, what kind of distance in miles do you get with the 10 or 13dbi cushcraft yagi in a rural nlos enviroment? 6-8-10 miles? under a medium path interference?
We are in one of the worst RF environments - San Francisco Bay Area - Contra Costa County. Noise floor is about -82dB to -85dB.
Radios are on a 3800 foot mountain with lots and lots of dishes, transmitters, etc. Nearest customer is about 2.2 miles (SM power is turned WAY down). Furthest customer is 15 miles (with -64dB signal). I think I can push that to 25 miles as doubling the distance takes 6dB.
this is the session stats with the antenna type (I think al of the Yagis are Cushman)
LUID: 002 : 10dBi Yagi
Site Name : Horan
Software Version : CANOPY 7.3.6 Oct 24 2005 12:06:56
FPGA Version : 070605 (DES Sched) P9
Session Timeout: 0, AirDelay 491 (approximately 13.67 miles (72177 feet))
Session Count: 2, Reg Count 1, Re-Reg Count 1
RSSI (Avg/Last): 1729/1717 Jitter (Avg/Last): 6/2 Power Level (Avg/Last): -67/-67
DnRate(SM): 1200 DnLimit(SM): 1200 UpRate(SM): 400 UpLimit(SM): 400 (kbit)
LoUpCIR(SM): 0 LoDnCIR(SM): 0 (kbps)
Rate : VC 18 Rate 2X/1X
LUID: 003 : Integrated Radio (12.5dB antenna)
Site Name : Mike Dachuk
Session Timeout: 0, AirDelay 498 (approximately 13.86 miles (73206 feet))
Session Count: 2, Reg Count 2, Re-Reg Count 0
RSSI (Avg/Last): 1675/1675 Jitter (Avg/Last): 4/2 Power Level (Avg/Last): -68/-68
Rate : VC 19 Rate 2X/1X
LUID: 004 : 8dBi Maxrad panel antenna
Site Name : Saeedi
Session Timeout: 0, AirDelay 89 (approximately 2.48 miles (13083 feet))
RSSI (Avg/Last): 1569/1569 Jitter (Avg/Last): 5/5 Power Level (Avg/Last): -71/-71
DnRate(SM): 600 DnLimit(SM): 600 UpRate(SM): 300 UpLimit(SM): 300 (kbit)
Rate : VC 20 Rate 1X/1X
LUID: 005 : 13dB Yagi through light foliage
Site Name : Anthony Grundstadt
Session Timeout: 0, AirDelay 383 (approximately 10.66 miles (56301 feet))
RSSI (Avg/Last): 1767/1795 Jitter (Avg/Last): 5/7 Power Level (Avg/Last): -66/-66
DnRate(SM): 1200 DnLimit(SM): 1200 UpRate(SM): 600 UpLimit(SM): 600 (kbit)
Rate : VC 21 Rate 2X/1X
LUID: 006 : Integrated 12.5dB antenna
Site Name : Andy Dickson
Session Timeout: 0, AirDelay 456 (approximately 12.70 miles (67032 feet))
RSSI (Avg/Last): 1646/1649 Jitter (Avg/Last): 3/5 Power Level (Avg/Last): -69/-69
DnRate(SM): 1800 DnLimit(SM): 1800 UpRate(SM): 900 UpLimit(SM): 900 (kbit)
Rate : VC 22 Rate 2X/1X
LUID: 007 : Integrated 12.5dB antenna
Site Name : Dominguez
Session Timeout: 0, AirDelay 499 (approximately 13.89 miles (73353 feet))
RSSI (Avg/Last): 1604/1598 Jitter (Avg/Last): 6/5 Power Level (Avg/Last): -70/-70
DnRate(SM): 2400 DnLimit(SM): 2400 UpRate(SM): 1200 UpLimit(SM): 1200 (kbit)
Rate : VC 23 Rate 2X/1X
LUID: 008 : Integrated 12.5dBi antenna
Site Name : Kevin Dutt
Session Timeout: 0, AirDelay 500 (approximately 13.92 miles (73500 feet))
RSSI (Avg/Last): 1758/1787 Jitter (Avg/Last): 4/6 Power Level (Avg/Last): -67/-66
Rate : VC 24 Rate 2X/1X
LUID: 009 : 13dB yagi
Site Name : HIE Brentwood
Session Timeout: 0, AirDelay 421 (approximately 11.72 miles (61887 feet))
Session Count: 8, Reg Count 8, Re-Reg Count 0
RSSI (Avg/Last): 1553/1550 Jitter (Avg/Last): 6/3 Power Level (Avg/Last): -72/-72
Rate : VC 25 Rate 2X/1X
LUID: 010 : 13dBi yagi
Site Name : Renner, Adda
Session Timeout: 0, AirDelay 543 (approximately 15.12 miles (79821 feet))
Session Count: 1, Reg Count 1, Re-Reg Count 0
RSSI (Avg/Last): 1615/1628 Jitter (Avg/Last): 4/5 Power Level (Avg/Last): -70/-70
DnRate(SM): 1200 DnLimit(SM): 1200 UpRate(SM): 500 UpLimit(SM): 500 (kbit)
Rate : VC 26 Rate 1X/1X
LUID: 011 : 13dBi yagi
Site Name : Brentwood Press Brentwood
Session Timeout: 0, AirDelay 413 (approximately 11.50 miles (60711 feet))
RSSI (Avg/Last): 1677/1692 Jitter (Avg/Last): 5/4 Power Level (Avg/Last): -68/-68
DnRate(SM): 10000 DnLimit(SM): 10000 UpRate(SM): 10000 UpLimit(SM): 10000 (kbit)
Rate : VC 27 Rate 2X/1X
LUID: 012 : 13dBi yagi
Site Name : Solari
Session Timeout: 0, AirDelay 513 (approximately 14.28 miles (75411 feet))
Session Count: 30, Reg Count 28, Re-Reg Count 2
RSSI (Avg/Last): 1677/1660 Jitter (Avg/Last): 4/6 Power Level (Avg/Last): -68/-69
Rate : VC 28 Rate 2X/1X
LUID: 013 : Integrated 12.5dB antenna
Site Name : CDF Station
Session Timeout: 0, AirDelay 80 (approximately 2.23 miles (11760 feet))
Session Count: 14, Reg Count 14, Re-Reg Count 0
RSSI (Avg/Last): 1546/1542 Jitter (Avg/Last): 5/4 Power Level (Avg/Last): -72/-72
DnRate(SM): 256 DnLimit(SM): 256 UpRate(SM): 128 UpLimit(SM): 128 (kbit)
Rate : VC 29 Rate 1X/1X
LUID: 014 : 13.5dBi yagi
Site Name : Matt Merideth
Session Timeout: 0, AirDelay 411 (approximately 11.44 miles (60417 feet))
Session Count: 4, Reg Count 4, Re-Reg Count 0
RSSI (Avg/Last): 1552/1559 Jitter (Avg/Last): 5/5 Power Level (Avg/Last): -72/-71
Rate : VC 30 Rate 1X/1X
LUID: 015 : 13.5dBi yagi
Site Name : Revel
Session Timeout: 0, AirDelay 519 (approximately 14.45 miles (76293 feet))
Session Count: 25, Reg Count 13, Re-Reg Count 12
RSSI (Avg/Last): 1583/1565 Jitter (Avg/Last): 4/3 Power Level (Avg/Last): -71/-71
Rate : VC 31 Rate 2X/1X
LUID: 016 : 13dBi yagi (marginal LOS)
Site Name : Brentwood Press - Antioch
Session Timeout: 0, AirDelay 338 (approximately 9.41 miles (49686 feet))
Session Count: 3, Reg Count 3, Re-Reg Count 0
RSSI (Avg/Last): 1627/1586 Jitter (Avg/Last): 4/4 Power Level (Avg/Last): -70/-71
Rate : VC 32 Rate 2X/1X
LUID: 017 : Integrated 12.5dBi antenna
Site Name : Walter Chincilla
Session Timeout: 0, AirDelay 493 (approximately 13.73 miles (72471 feet))
RSSI (Avg/Last): 1562/1560 Jitter (Avg/Last): 4/5 Power Level (Avg/Last): -71/-71
Rate : VC 33 Rate 2X/1X
Just to let everyone know on this post that it was the 100 watt pacific wireless yagi’s. They just aren’t a quality yagi, as soon as we went anywhere that we tried the pacific wireless yagi’s and tried the cushcraft we got a solid connection immediately. Just a heads up for everyone who needs a quality yagi in nlos rural setting go with true cushcraft and stay away from pacific wireless which is a division of cushcraft that makes oem yagi products.
The model # on the Pacwire yagis is PAWYA9 9, 11 , 13dbi
http://www.pacwireless.com/products/YA9_DataSheet.pdf
Glad you solved your problem.
What was the Part Number of the Yagi that worked?
Here is the link to the yagi that we are using with great success.
http://www.cushcraft.com/comm/support/p … 0YAGIS.PDF
PC9013N 13dbi
PC8910N 11dbi
PC906N 8.5dbi
