I see you guys are using 900 Mhz?You should check out with a 17.5 and 14.5 Dbi Yagi antenna. By Kp Performance Antennas
www.kpperformance.ca
Take care
Are you done spamming the forums yet?
go away
Wow this guy just doesn’t give up.
Hmm where’s the report a thread button.
mikehodges wrote: Paper clips and aluminum foil will work better ….. Just kidding … but really stop spamming us
IMO there is no need to keep throwing salt on an old wound since he apologized.
