Is there such a thing that can be enabled? A script that can be run?
Consistently once a week I have an AP that starts hearing so much noise almost all the connections drop. I bounce between 906 and 920. 906 has noise, I switch to 920. 920 has noise I switch back to 906.
I’m certain it’s a competitor WISP trying to mess with me.
Is there a way to automatically have the AP switch so I don’t have the outage?
DFS is used for radar avoidance. It is not available in the 900MHz product. You will have to manually work around the interference.
