Do I need 2 of these to create a ptp link using 900mhz?
C009045B001A
Yes, you will need two of these along with the appropriate antennas.
Thank you
Hello, here is an example BOM for your setup (pulled from LINKPlanner).
Part Number | Description | Quantity | Notes |
600SSH | SURGE SUPPRESSOR | 4 | |
C009045B001A | PTP 450 900 MHz END - Connectorized | 2 | |
EW-E4PT450-WW | PTP 450 Extended Warranty, 4 additional years (per END) | 2 | |
N000900L001B | PoE Gigabit DC Injector, 15W Output at 30V, Energy Level 6 Supply | 2 | |
N000900L007A | CABLE, UL POWER SUPPLY CORD SET, US | 2 | |
N009045D003A | 900 MHz 12 dBi gain directional antenna (Dual Slant) | 2 | Includes the mounting bracket for the antenna and radio |
WB3176A | 328 ft (100 m) Reel Outdoor Copper Clad CAT5E (Recommended for PTP) | 1 |
Hi
Did you set up your 900 MHz PTP link?
If so how is it doing?
What is the path distance, obstructions and noise floor?
Good luck with the link.
Stay Safe
