Does anyone have any recommendation on 900mhz Sector Antenna’s, preferably the 120 deg? I would like some lightweight with a small footprint since I am going on a Non Guyed Tower and I don’t need much wind load?
I can tell you that we have a sectorized facing north, and one south… you might as well call them 160-180 degree sectorized antennas… we can connect pretty much all around them.
Z
well tiltek is probably the best i have ver used but there not light
We use til-tek 120 degree antennas. I believe they are about 50 lbs each but the windload isn’t too much.
Pacwireless has some good antennas in the 900 mhz range.
