I want to know whether we can able to merge two WiFi APs. If one AP was configured and another AP just power on. There is any possibility to merge both the APs. If possible, tell me how to perform the action.
hi,
not able to get the requirment clearly, please explain with more details, we shall be able to help.
Hi Madhan,
It sounds like the Mesh recovery feature might help you. See the document linked in this post
You'd have to configure the the first device as mesh base and enable the recovery profile on it. The second device that is powered on without being configured would attempt to act as mesh client and connect to the recovery profile. Once it has done so and obtained network connectivity you can fully configure that device and then deactivate the recovery profile.
Thank you for your reply.......
Let I try the action the reply you.....
