Access control not working in xv2
Hello members, am trying to configure access controll in XV2-2X AP but i cant see the configuration. even if i do it in cnmaestro, the configuration is not reflected in the AP GUI.
I tried with cnPilot E600 and it works perfectly. Please guide.
Client does not want guest users to access their LAN Equipment
on xv2-2x
on cnpilot e600
Hi Timothy, Try to use the Client Isolation function under the WLAN instead (network-wide), let me know if it helps
Thanks @Andy_Stevens , i tried that and it failed. But i later got it. The configuration is available only on CLI and cnmaestro
Aha, yes I was referring to the client isolation function in cnMaestro.
I will add that next time :).
Good, the problem is solved. Cheers!
