Anyone can help me to write correct USERDN to autenticate to all active directory tree??? i atached image,
thanks!
thanks!
Are you trying to authenticate Guest Users from the Active Directrory on cnPilot E400 / E500 devices?
WIth Regards,
Channareddy
Yes i try but i need autenticate in same SSID all organitzations Units
BaseDN DC=net,DC=XXX,DC=es
useRdn ... ONLY WORKS ONE LEVEL Ou FOR EXAMPLE OU=XXX,DC=net,DC=XXX,DC=es
but if have inside ou than ou not login,
i want can login from all DC=net,DC=XXX,DC=es
i try with put inside in new OU and inside group with members to other organization and no work too,
please help
