The 60GHz cnWave product solution from Cambium Networks provides your subscribers with high speed access. With good planning, your initial deployment with a single POP may be adequate.
As your network grows, the demand may start to exceed its capacity. To increase capacity, you could plan to add more POPs. If you are unable to find an appropriate site, you could still place a 2nd POP at the same location as your 1st POP and create links with few 1st hop DNs. Further, you can “optimize DPA zone allocation” to split your mesh network and allow each POP to serve CNs and DNs of corresponding zones.
