Advantage SM & Classic AP
Will advantage SM’s talk to classic AP’s?
thanks.
I am not doubting you by any means keefe007 but is there anyone else that has a network where Advantage SM’s are connecting to Classic/Legacy AP’s that can confirm my question?
Yes, you just need to run the sm’s in software mode
Yes, they will
I have a classic 900mhz AP with 2 advantage SMs attached to it.
the set up you are requesting will work
you will not get any of the advantage benifits from this set up.
