Downlink Data %
Control Slots (Range: 0–10)
Sustained Uplink Data Rate (kbps) (Range: 0–20,000 kbps)
Uplink Burst Allocation (kbits) (Range: 0–500,000kbits)
Sustained Downlink Data Rate (kbps) (Range: 0–20,000 kbps)
Downlink Burst Allocation (kbits) (Range: 0–500,000kbits)
The above is a cut from my 900mhz config page. What should I set the above to? The Current setting are:
Downlink Data 75 %
Control Slots (Range: 0–10) 0
Sustained Uplink Data Rate 10000(kbps) (Range: 0–20,000 kbps)
Uplink Burst Allocation 10000(kbits) (Range: 0–500,000kbits)
Sustained Downlink Data Rate 10000 (kbps) (Range: 0–20,000 kbps)
Downlink Burst Allocation 10000 (kbits) (Range: 0–500,000kbits)
To get the max throughput what should I set this to?
