Hello Team,
Which router will you advise for the below requirements:
• 1 Internet Smart Indoor WiFi RoutersLot 2 Routers Standards IEEE 802.11a, 802.11b, 802.11g, 802.11n, 802.11ac, Frequency 2.4 GHz and 5 GHz (concurrent) MIMO 3 x 3 with MU-MIMO Wave 2
• Support 2.4 GHz Physical Data Rate 300 Mbps Internal Antenna: Yes RF Output Power: High Power PA PoE 802.3af Wall/Ceiling Mount: Yes Gigabit Ethernet: Yes Security Lock: Kensington Lock Slot LED: One System LED AC Power Adapter:12V/1.5A Hardware Reset Button: Yes
…and an AP for below requirement:
2 2.4GHz 300Mbps 9dBi Outdoor Wireless Access Points Routers- Lot 2 AP / Client / AP Router / AP Client Router (WISP) operation modes, Passive PoE Adapter supports up to 60 meter (200 feet) Power over Ethernet deployment and allows the device to be reset remotely.
Richard
