i write here wondering if anyone has faced this kind if issue:
New SM with installation color code (CC: 0) connect to the AP.
Start configuring SM setting the right color code (no mistakes) of the AP where it’s connected.
Reboot
SM don’t connect anymore
This happens very few times but happens and seems that this happens if a router is connected to the SM.
No frequency problems, no low power level or SNR etc…
A workaround is to change the SM (because it does’nt connect anymore to the AP even if is correctly configured), disconnect the router, power on the SM without router, configure the SM, reboot and after successful connect to the AP, connect the router.
What equipment is this? Curious if this might be what some of our providers are seeing. They will call and say they can’t connect and when we check the AP we never see the SM even attempting. Are you able to default the SM and use it at a different site just fine? I think a number of our installers tend to have their laptops plugged in to the SM while installing/configuring and once they get a connection they move it to the router, but maybe not.
What I was wondering is the SM dead after it won’t connect, or can you bring it back, default, get it working in the lab and then deploy it to another location just fine?
Charlie:
Is configured in DHCP (maybe without router there’s a mismatch between router DHCP?).
I don’t know if is possible access the SM over ethernet, i did’nt tried.
