After troubleshooting my 5.4 or 5.7GHz 30/60 or 150/300 Mb OFDM Backhaul it still isn't acting right, what's the next step?
Solution: Reset radio to "Gold Code" (Factory default settings) by pressing and holding the Power IDU reset button while applying power, continue to hold for 45 seconds. This resets the radio back to "Gold Code", then upgrade to the current version of firmware.
Default IP will be (Master 169.254.1.2) (Slave 169.254.1.1)
