Android cnMaestro captive portal errors
I keep getting
"The webpage at http://connectivitycheck.gstatic.com/generate_204"
error when connecting with some android devices.
I think there was a post on suggesed whitelist settings for IOS and Android captive portal issues but can't seem to find it.
Any pointers?
Martin,
Please let us know on which Android version this issue is seen?
And also let us know which device you are using?
Immanuel
I got same from any version of android, & laptop while connecting the Guest Network. Any solution?
Nazmul
NazmulHasan,
Which version of firmware are you running on your AP? If you're using 3.5 please upgrade to 3.5.1
Greetings
To be clear, I was testing this with the Voucher feature only.
The Cambium tech team was great in quickly identifing the problem and this has been resolved in the latest software, v3.5.1-r1.  I've been testing it and it works fine now.
Regards
Martin
