Does anyone know what antenna type used in V3000?
When you purchase the V3000 you need to consider a number of options:
The basic is the Radio C600500C024A:
To which you would attach either of the two dish options we have:
C600500D002A 60GHz cnWave V3000 Client Node Antenna Assembly, 40.5 dBi, 4 Pack – Max EIRP ~55dBm
This is the equivalent of a 1ft parabolic dish.
or
C600500D003A 60GHz cnWave V3000 Client Node Antenna Assembly, 44.5 dBi, 4 Pack – Max EIRP ~60dBm
This is the equivalent of a 2ft parabolic dish.
The advantage of using this design over a basic dish design is the ability to utilize many more patches in the 60GHz array, allowing additional conductive power to be spread over many more transmitters for a cleaner signal and you get beamsteering even with these high gain antennas.
In addition to the dish you then can chose the bracket type, a basic tilt or the precision bracket.
