I'll be using the 45600 to extend my network since OSP cable is not an option. Is there any speical configurations on a cisco switch that needs to be done?
Hi David,
Could you pleaseĀ provide some more informationĀ regardiing the set-up.
Please send us an email to support@cambiumnetworks.com along with your contact detailsĀ and we will contact you.
Regards,
Hardik Patel
What sort of setup do you have in mind? Which model of Cisco switch and the software version?
Depending on the setup, you may have to configure switchport mode access, or switchport mode trunk, with native encapsulation, or dynamic etc.
Just switching, how about routing (depending if your Cisco feature set is IPBASE or ADVANCED IP SERVICES etc? VLANs etc.
Best if you can provide more details, the logical and physical setup.
