Hi all,
I’m trying to test PPPoE client feature included on 9.x releases.
I setted up a PPPoE concentrator on my NOC.
I’m sure it works, because the following configuration is working:
NAT disabled on Canopy SM
PPPoE client configured on client pc, directly connected to Canopy SM (Windows XP native client)
When I configure the same service/username/password on the SM, of course enabling NAT, the SM PPPoE status says “connecting” and nothing happens
PPPoE Log says:
00:00:21 UT : Mon Jan 01 2001 : start_ppp_link: In Session Auto Connect
00:00:21 UT : Mon Jan 01 2001 : open (link 0xea011c): IPCP
00:00:21 UT : Mon Jan 01 2001 : ppp_fsm (link 0xea011c): IPCP state: INITIAL -> STARTING
00:00:21 UT : Mon Jan 01 2001 : ppp_fsm_init (link 0xea011c)
00:00:21 UT : Mon Jan 01 2001 : open (link 0xea011c): LCP
00:00:21 UT : Mon Jan 01 2001 : ppp_fsm (link 0xea011c): LCP state: INITIAL -> STARTING
00:00:21 UT : Mon Jan 01 2001 : poe_sendctl code 0x09, state:INIT->PADISENT, tags:
15:26:49 UT : Mon Nov 09 2009 : PPPoE rcv err unacceptable tag value; pkt type 0x7
15:26:50 UT : Mon Nov 09 2009 : poe_sendctl code 0x09, state:INIT->PADISENT, tags:
15:26:50 UT : Mon Nov 09 2009 : PPPoE rcv err unacceptable tag value; pkt type 0x7
15:26:52 UT : Mon Nov 09 2009 : poe_sendctl code 0x09, state:INIT->PADISENT, tags:
15:26:52 UT : Mon Nov 09 2009 : PPPoE rcv err unacceptable tag value; pkt type 0x7
15:26:56 UT : Mon Nov 09 2009 : poe_sendctl code 0x09, state:INIT->PADISENT, tags:
15:26:56 UT : Mon Nov 09 2009 : PPPoE rcv err unacceptable tag value; pkt type 0x7
15:27:05 UT : Mon Nov 09 2009 : poe_sendctl code 0x09, state:INIT->PADISENT, tags:
15:27:05 UT : Mon Nov 09 2009 : PPPoE rcv err unacceptable tag value; pkt type 0x7
15:27:22 UT : Mon Nov 09 2009 : poe_sendctl code 0x09, state:INIT->PADISENT, tags:
15:27:22 UT : Mon Nov 09 2009 : PPPoE rcv err unacceptable tag value; pkt type 0x7
15:27:56 UT : Mon Nov 09 2009 : poe_sendctl code 0x09, state:INIT->PADISENT, tags:
15:27:56 UT : Mon Nov 09 2009 : PPPoE rcv err unacceptable tag value; pkt type 0x7
Did anybody success with PPPoE client?
What could be the problem?
