i try to undestand a problem specifically with the two... Just to verify a theorie... When i used force 300 with powerbox pro i got under a lot of instability like all port from the powerbox pro disconnect and reconnect and i can say a got this problem from two site... i got more stability at 100 mbps but got reboot problem from 1 or 2 time a day... it's start to make me crazy... I change the cable ,Routerboard ,Power supply and the Radio...
Try this post regarding pause frames, see if it helps… basically looks like try latest Mikrotik firmware plus beta cambium firmware…
https://community.cambiumnetworks.com/t5/ePMP-3000-2000-and-1000/EPMP-2000-and-Mikrotik-Pause-Frames/
yeah i desactivated the flow control between them... and use the last firmware too i change the radio the board the cable the power supply... im out of solution
