API Integration with cnMaestro On-Premises 5.2.0-r3 – Authentication and Endpoint Guidance
Hello,
We are running cnMaestro On-Premises version 5.2.0-r3 in a production ISP environment and we are planning to integrate it with our internal monitoring and provisioning system via API.
Before implementing it in production, I would like to clarify a few technical aspects:
  1. What is the recommended authentication method in 5.2.0-r3?
    • API Token?
    • Session-based authentication?
    • Basic Auth over HTTPS?
  2. Is there an official and up-to-date API reference specifically for the On-Prem 5.2.0-r3 build?
  3. Are there differences in available endpoints or behavior between:
    • cnMaestro Cloud
    • cnMaestro On-Prem 5.2.0-r3
  4. What is the correct workflow to programmatically:
    • Retrieve full device inventory (APs and SMs)
    • Query real-time device status (online/offline, RSSI, SNR, traffic)
    • Pull historical statistics per AP or per sector
    • Obtain client association details
  5. Are there any rate limits, session timeouts, or API performance considerations we should be aware of for production use?
Additionally, if possible, I would appreciate:
  • A sample authentication request (curl example preferred)
  • A sample request to retrieve the device list
  • Any best practices regarding secure API usage in an ISP environment
Thank you for your assistance.
Best regards,
This topic was automatically closed 90 days after the last reply. New replies are no longer allowed.
