Are QoS settings honored during a wireless link test?
Specifically, if I have enabled Traffic Priority and VoIP Priority, will VoIP traffic continue to have priority during a wireless link test?
Chris
Chris
I know that the speed QoS is honored... e.g. if you set a 1mbps DL and 1mbps UL, your link test will be capped at that speed. I'm fairly certain that VoIP QoS should be prioritized, even during a link test. Maybe later today I will test and see what happens.
Now you've got me wondering if the wireless link test treats all existing traffic as priority, and just fills the pipe to find the maximum throughput. That would be fantastic.
