I know this has been discussed before but I didn’t see any kind of resolution.
When using CNUT to change firmware versions in radios, SM AutoUpdate does not work. I have had this issue with more than one AP at more than site. When I telnet in and issue the update command, I get the message that
Autoupdate currently Disabled
Currently, most of my SMs have NAT turned on and I do not have the Radio Public IP active as I access them via the APs LUID. Does anyone know of a work-around or solution other than configuring the SMs Radio Public IP and putting on the network? That requires too many reboots for my commercial customers to deal with
Yah, I have no problem getting CNUT to see the SMs and list them after and AutoDetect. The issue is not in the SMs or even CNUT - it is the APs that are not cooperating. With CNUT I can use the tool to enable AutoUpdate on an AP, and it will check the status, and transfer the files to the AP. When it tries to enable AutoUpdate it says no SNMP response. When I manually enter the update command in Telnet, the AP says “Screw You, I won’t let you do that”. :lol:
Also I’m not sure what in the AP configuration would affect the AutoUpdate. And the Update Application Address in the AP doesn’t seem to make any difference.
My destktop has public IP. The autoupdate address is the IP of my PC. CNUT 2.2. SMs have private IPs, but this is not importend becouse if I update only the APs the SMs will autoupdate. I have tryed this on two clusters with 8.1, no problems.
the update IP for the AP config should be the IP of the machine with cnut on it. It should be on the same range as all of you AP’s
I believe there are two ways of doing it. #1 is to have that machine host the files #2 is to have the AP host the files. im not sure if there are any benifits of either one.
if you are having an snmp error make sure the snmp string on cnut and the AP config page match. also make sure the AP has the update IP of your cnut box
Yup, the update IP does not make a difference - with or without it I get the same message from the AP. There is no issue with SNMP or addressing - I can access and update the AP with no issues. :?
I am trying to update to 7.3.6, and have had similaar troubles with the atuo update. Is there any other way around this, without changing all SM IP’s to public?
CNUT 1.1 did not make any difference. It still seems to be an issue with the radios and not CNUT as I can get AutoAupdate on in other APs without issue.
