Hello!
I’m new to cambium products, but I’ve inherited a setup where there is an E410 and an E430 AP installed at a remote location with intermittent internet connectivity. In this setup the E410 is the autopilot master, firmware is at 4.2.2.1-r3.
This setup is quite elegant and performant, roaming is seamless all is good etc.
However there are a few settings in the autopilot webui which are not exposed and I’d like them to be configured. I can do these configurations from the individual device webui or cli but that config gets overwritten by the autopilot config.
If I understand correctly I need to use the autopilot > Configugre > CLI overries options in the autopilot webui to get my config merged with the autopilot config.
Unfortunately i get stuck on the correct syntax or something else, because:
This works:
interface vlan 1
ip dhcp request-option-all
but if I continue with further settings for other vlans this does not work: the APs rebooting, becoming slow, in the cli ‘show config’ erros out.
interface vlan 1
interface vlan 100
no management-access
interface vlan 101
interface vlan 130
Any help would be appriciated. I get that the on premises or the cloud hosted cnmaestro is much more capable but at the moment I cannot run a VM at that site; internet access is spotty; and I would rather not switch back to the individual AP config if autopilot exists.
Thanks in advance!
