Aux Mode Cable length for PTP450i
How long can the Aux Mode Cable length be when Powering a cnpulse or UGPS from a PTP450i?
Hello, please see this post for more information: http://community.cambiumnetworks.com/t5/PMP-FAQ/Cable-Diagram-for-450i-and-450m-to-UGPS/m-p/52198#M275
Update:  10m is the maximum recommended cable length for this type of cable.
It can work up to 40m, but it is highly recommended that you restrict the cable length to 10m.
If the cable is greater than 5m in length, it is recommended that surge suppression is used.
Another note is to ensure that the 6-pin cable connectors are suitable for solid wire conductors (Ethernet type cables).  If the connectors are intended for stranded cables, they may not work reliably with solid wire cables, and can result in latent issues.
