Azure Enterprise Portal and cnMaestro 5.1
I think the ability to create Enterprise Captive Portals has disappeared in the latest version of cnMaestro.
Am I right?
If so, what options do I have to create a new Azure portal?
Best Regards
Edu
I am a bit confused, I have seen the demo ‘EasyPass with Microsoft Azure’, but my cnMaestro X 5.1 interface is totally different from the one in the demo, I don’t see all these menus in ‘Network Services’.
Maybe my problem is related to some limitation in my version.
Edu
Can you show a screenshot of what you are seeing?
Are you certain you are running 5.1.0?
v 2025-02-14 130706
v 2025-02-14 130806
Hmm, that’s very strange. Could you try clearing your browser cache and reloading the front page of your cnMaestro instance? At this point I think it’s unlikely to make a difference, but it’s worth a try.
I’ve cleared the cache, I’ve even tried using a different browser, but nothing has changed.
I have tried to update the 5.1.0-r4 package again without success, it refuses when it checks that it is the existing version.
I’m afraid I don’t have any other suggestions, except for raising a support ticket. The On-Premises 5.1.0 user guide definitely suggests that you should have more options in your Network Services menu.
Thanks Simon, I have taken your advice and have opened a support case.
Edu
This topic was automatically closed 90 days after the last reply. New replies are no longer allowed.
