I have a BH 5.7 in my network that lost the ping every 2 hours, and I have to reconect it to go alive again.
Has the following configuration:
Device Type : 5.7GHz - BackHaul - Timing Slave - 0a-00-3e-ff-7a-ae
Software Version : CANOPY 8.2 BH-DES
Software BOOT Version : CANOPYBOOT 1.0
Board Type : P10
FPGA Version : 060707
PLD Version : 9
Uptime : 00:38:12
System Time : 14:41:46 01/08/2001
Ethernet Interface : 100Base-TX Full Duplex
Antenna : Vertical
Subscriber Module Stats
Session Status : REGISTERED VC 18 Rate 1X/1X VC 255 Rate 1X/1X
Registered BH : 0a-00-3e-ff-7a-21
RSSI : 552
Power Level : -76 dBm
Jitter : 1
Air Delay : 2282 approximately 21.18 miles (111818 feet)
Device Type
Timing Mode : Timing Slave
Link Speeds : 100 Base T Full Duplex
Web Page Configuration
Webpage Auto Update : 0 Seconds (0 = Disable Auto Update)
Bridge Configuration
Bridge Entry Timeout : 25 Minutes (Range : 25 – 1440 Minutes)
Bridging Functionality : Enable
MAC Control Parameters
Power Up Mode With No 802.3 Link : Power up in Operational Mode
Frame Timing
Frame Timing Pulse Gated : Enable (If SM out of sync then do not propagate the frame timing pulse)
Layer 2 Discovery Destination Address
Multicast Destination Address : LLDP Multicast
And the syslog shows:
21:59:59 UT : Mon Jan 01 2001 : File src/syslog.c : Line 1283 Time set
06:59:59 UT : Tue Jan 02 2001 : File src/syslog.c : Line 1283 Time set
00:00:24 UT : Mon Jan 01 2001 : File src/syslog.c : Line 1283 Time set
00:00:26 UT : Mon Jan 01 2001 : File src/syslog.c : Line 1283 Time set
00:00:00 UT : Mon Jan 01 2001 : File src/syslog.c : Line 1181 System Reset Exception –
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 417 System Startup
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 422 Software Version : CANOPY 8.2 BH-DES
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 426 Software Boot Version : CANOPYBOOT 1.0
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 436 FPGA Version : 060707
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 440 FPGA Features : DES, Sched
01:32:10 UT : Mon Jan 01 2001 : File src/syslog.c : Line 1283 Time set
23:00:00 UT : Wed Jan 03 2001 : File src/syslog.c : Line 1283 Time set
22:00:00 UT : Sat Jan 06 2001 : File src/syslog.c : Line 1283 Time set
02:52:22 UT : Tue Jan 09 2001 : File src/syslog.c : Line 1283 Time set
00:00:29 UT : Mon Jan 01 2001 : File src/syslog.c : Line 1283 Time set
01:57:21 UT : Mon Jan 01 2001 : File src/syslog.c : Line 1283 Time set
23:59:59 UT : Tue Jan 02 2001 : File src/syslog.c : Line 1283 Time set
00:00:27 UT : Mon Jan 01 2001 : File src/syslog.c : Line 1283 Time set
09:59:59 UT : Mon Jan 01 2001 : File src/syslog.c : Line 1283 Time set
02:59:59 UT : Tue Jan 02 2001 : File src/syslog.c : Line 1283 Time set
16:55:06 UT : Tue Jan 02 2001 : File src/syslog.c : Line 1283 Time set
05:00:00 UT : Fri Jan 05 2001 : File src/syslog.c : Line 1283 Time set
18:00:00 UT : Sun Jan 07 2001 : File src/syslog.c : Line 1283 Time set
00:00:28 UT : Mon Jan 01 2001 : File src/syslog.c : Line 1283 Time set
08:59:59 UT : Mon Jan 01 2001 : File src/syslog.c : Line 1283 Time set
17:00:00 UT : Tue Jan 02 2001 : File src/syslog.c : Line 1283 Time set
17:49:07 UT : Wed Jan 03 2001 : File src/syslog.c : Line 1283 Time set
20:59:59 UT : Wed Jan 03 2001 : File src/syslog.c : Line 1283 Time set
12:59:59 UT : Fri Jan 05 2001 : File src/syslog.c : Line 1283 Time set
15:28:17 UT : Sun Jan 07 2001 : File src/http_utils.c : Line 35 Reboot from Webpage.
00:00:00 UT : Mon Jan 01 2001 : File src/syslog.c : Line 1181 System Reset Exception – Watchdog Reset
15:29:00 UT : Sun Jan 07 2001 : File src/syslog.c : Line 1283 Time set
18:27:08 UT : Sun Jan 07 2001 : File src/syslog.c : Line 1283 Time set
19:29:03 UT : Sun Jan 07 2001 : File src/syslog.c : Line 1283 Time set
14:22:00 UT : Mon May 04 2009 : File src/misccmds.c : Line 171 Date/Time Set
19:29:19 UT : Sun Jan 07 2001 : File src/syslog.c : Line 1283 Time set
23:08:48 UT : Sun Jan 07 2001 : File src/syslog.c : Line 1283 Time set
14:04:11 UT : Mon Jan 08 2001 : File src/syslog.c : Line 1283 Time set
Somebody knows what can be happening with this BH
It loses ping, but does it actually drop the wireless session? Post your link test results - if it’s a wireless issue you’ll need to realign and possibly need bigger reflectors.
The other issue is it could be ethernet lockup. 8.x had many, many problems with that. Moto didn’t get the bulk of them resolved until 8.2.7. 9.4 is the current stable firmware release and it would be highly recommended to get your link up to that version.
It not drop the wireless session, only loses the ping. I’m doing ping directly from the ethernet port.
Where I can find the current stable firmawere release?
