Any Tips for reducing jitter?
Device type
5.7GHz - BackHaul - Timing Slave - 20 MBit - (P8)
Software Version
CANOPY 7.1.4 Apr 26 2005 11:07:45 BH20-DES
RSSI
1569 (-54 dBm)
Jitter
7
Air Delay
1251 (approximately 11.61 miles (61299 feet))
Make sure the power level is turned down, if it’s too high you could be interfering with your own SM.
7 is good
As Jerry said, on the 20 Mbps units, 7 is good. To get a better reading, temporarily set your link to 10 Mbps, then check the jitter.
What do your link tests look like?
