Bandwidth Issue
I got my equipment about 2 weekends ago, and i can say i have been very unhappy with the performance and the tech support i am being given. I am with inforamp and they advertise 6 meg down. Well im lucky if i get 100 kbps down. I have the most clear line of site you can get i average between 1500 and 2300 rssi and 1-7 jitter. Still no speed. here are my stats
Device type 5.2GHz - Multipoint - Subscriber Modem - 0a-00-3e-00-36-cb
Software Version CANOPY4.2.1 Apr 16 2004 15:23:05 SM-DES
Software Boot Version CANOPYBOOT 2.5
FPGA Version 06240308 (Single, 40MHz ExtBus, DES, Type0)
Uptime 00:23:37
System Time 02:09:19 10/05/2004
Ethernet Interface 100Base-TX Full Duplex
Subscriber Modem Stats
Session Status REGISTERED
Registered AP 0a-00-3e-00-23-76
RSSI 1911 Slicing Value not calibrated
Jitter 1
Air Delay 19 (approximately 0.18 miles (931 feet))
Radio Slicing Value 526 (decimal)
Radio Transmit Gain Setting 24 (decimal)
Radio Temperature Slicing Value not calibrated. Temperature not available.
Radio Power Level RSSI, Slicing Value, and Power Level not calibrated. Power Level not available.
LUID 15
IP Address 192.168.101.15
Registration Grant Status 0
Sustained Uplink Data Rate 10000 (kbps)
Uplink Burst Allocation 10000 (kbits)
Sustained Downlink Data Rate 10000 (kbps)
Downlink Burst Allocation 10000 (kbits)
First of all, calibrate your unit at motorola.canopywireless.com/calibrate.pho
and enter the value to your.unit.ip.address/mac.html
Than do a link test in the unit, it will show the available cell speed.
If that still ok, and still slow, your ISP has not engough bandwidth and/or uplink pipe.
Don’t forget, the max speed in the cell is 6mbps, and all of that is not dedicated do downlink! (probably 75% of that!)
Btw, this problem seems to me, i just bought my new prosche, and i cannot go faster than 80mph in the city, but my seller promised me it can go 180mph!!!
the link motorola.canopywireless.com/calibrate.pho came up with a page could not be displayed. second off i noticed this, this morning have i did a reboot on the paddle.
Sustained Uplink Data Rate 512 (kbps)
Sustained Downlink Data Rate 512 (kbps)
does that mean im capped at 512 down and 512 up?
sorry, try it with .php extension.
Yes, it seems, you are capped at 512kbps
