What are the performance benefits of hot swapping 3000s for 4500s, and will having F300s connected to the 4500 bases have a negative impact on the 4525L connections experience?
It was very well covered in the webinar some time ago.
Just swapped out a base with 30 x F300 connected and saw zero improvements as expected.
What metrics are compared?
Can you show us any numbers please?
Thank you.
Iām comparing how the 3000 performed by looking at DL quality and running 10 second speed tests on the same channel and bandwidth but I suppose if its noisy its noisy.
