Hi, I can’t get past 120Mbps in the speedtests. I have tried other brands with the same cables and it gives me up to almost 300Mbps via Wifi, even when I am at a 3 meters distance. What am I doing wrong?
Channel width might have defaulted to 20mhz?
Yes, 20mhz for 2.4 and 40mhz for 5GHz
It might be connected though the 2.4GHz, also see what 80MHz does.
I have separate SSIDs. One for 2.4 and one for 5 GHz.
Hi Gary, ok ok. Thanks
Thanks Gary for your recommendation,
I just update to version 6.5-r15
And looks fine now.
