Is there a timeline when the 100 limit will be removed or increased on cnMaestro?
We do not have an exect date as of now, However; I will try to check if I can get this information from the concern team.
Please feel free to contact us in case you need any further assistance.
You can always send us an email to support@cambiumnetworks.com with your query.
Regards,
Hardik Patel
Cambium Technical Support
Oops, I just saw this post after asking a question about the number of devices we can add. It looks like the current limit is 100. I have about 25 devices and I just tried to add another one and it said my beta version has limited device availability and that I was exceeding that limit so it did not add my device. Is this an error? If so, how do I fix it? Thanks
Please try again now -- you should be able to add up to 100.
It worked! Thank youÂ
