Is BFD supported for OSPF on theses L2/L3 switches?
BFD (Bidirectional Forwarding Detection) is not currently supported. It is in the roadmap.
Thanks.
BFD would be a great addition.
Awesome that you guys are looking at this as it makes failover between stretched transit vlan designs so much faster.
Thanks for the reply. Looking forward to it. It will make things simpler and reduce the amount of kit needed at each tower. Aaaand cnMeastro.
Cheers!
