Hi there,
I've red someone did the Elevate on MK Sextant.
Which file do I have to use in order to to the first boot using tftpd32?
Hi there,
It is recommended to use device elevator as much easier way of doing elevate on Mikrotiks
Dmitry
Cambium release note wrotes about an upgrade for the Mikrotik Sextant on 4.4.2 for resolving crash issues, where is it possible to download the firmware ? The device elevator install the 4.4.1
Thanks a lot
You can update to 4.4.2 after device elevator. Please download the 4.4.2 tar.gz using the following link:
https://support.cambiumnetworks.com/files/epmp-elevate/
lhg5-v4.4.2.tar.gz is for devices with NOR memory
sxtlite5-v4.4.2.tar.gz is for devices with NAND memory
Dmitry
Hi !
I need to find an updated device elevator for equipment LHG5HPND XL
Hi where can we get the Elevator tool, the Github URL is 404. Please re-establish it, even though we know you’ve discontinued support. Thanks
is a bit rudimental but works perfect (every LHG HW & FW version)
elevates without human interaction (click that, configure that …)
BR,
John
Yes I’ve seen that tool and I’ve also seen the price. Was hoping to try the Cambium tool. Any copies flying about?
