Blinking LED on the Canopy SM Lite Poe Power suply
Das anybody knows what a blinking LED on the Poersuply means ?
It the PSA15R-240/MOT from Phihong.
i called motorola tech support thursday about the blinking lite on the poe. they in all seriousness said they had know idea why it does it.
veeery helpful eh?
on edit: the blinking poe’s were attached to 3 ap’s that were damaged in a lightning storm so while there is no exact meaning , them blinking isnt a good sign
If I recall it’s over-current.
Jerry Richardson wrote:
If I recall it's over-current.
I agree. Or a bad power supply.
Most switching power supplies will shut down on overcurrent.
Regardless - something is broken, so swapping equipment/cables to determine the bad part is where I'd start.
Thanks to everyone, i got this morning an answer from the vendor of the Power supplys.
“On the PSA15R-240P(MOT)-R power supply, the LED blinks if the power supply is over-loaded, at which point the power supply goes into hiccup mode.
At 115VAC input if the power supply is over-loaded to 1.6A or at 230VAC input if the power supply is over-loaded 1.788A this condition will occur.”
