Chris_Bay
(Chris_Bay)
#1
so I see on the back of the box its marked 24 to 56v Poe... I was under the impression these are just normal force 180 radios just preconfigured.
is there a hidden golden nugget here, or an oops at the packaging plant? :)
and thanks, Ray! they just came in this morning.
CWB
(Richard B.)
#2
In the spirit of testing, did you attempt a 56v test?
Chris_Bay
(Chris_Bay)
#3
I did try .at 48v power, no lights. Wasn’t brave enough for passive.
CWB
(Richard B.)
#4
Don't blame you. These things run on smoke and once you let all the smoke out you can't get it back in.
