Bug found using 5.10.1
Bug alert. 5.10.1
Manual port speed setting are not working correctly. Works fine when in autonegotiate. Spent a couple of hours troubleshooting why we were getting less than 10 meg when MIR was set for 100 meg on a 4525 thinking we had a router/cable issue. Worked back to the radio and finally figured out that if you manually select port speed of 100 meg, it will pass less than 10 meg. 10 meg setting barely passes 1 meg. Going back to autonegotiate and everything is fine. We reproduced the issue at will on 2 different 4525s, both running 5.10.1. Not a show stopper by any means but something that needs correcting.
Hi @Riverrat,
Could you let me know what type of the networking equipment do you use on the other side of the link?
Do you see the same behavior on version 5.9.2?
Please send me a tech support file via PM while the issue is occurring.
I did a quick check in our lab using a Dell laptop and a Mikrotik RB, and I didn’t observe the same behavior.
Thank you.
it was a 4525 going to a 4500L. We were using a dell laptop and also tested through a TP-Link Deco router. We did not try it with 5.9.2 but will set that up and test next week. We were using a Dell laptop but will retry with an HP as well.
