With cnHeat 2.0 users can run building identification on predictions to determine how many buildings are covered at varying install heights and signal levels.
This feature can be found under project configuration. Simply click on a prediction and fill out the form before running.
In this example we see that 1.33% of the buildings are covered LOS to the tower at 2ft above the rooftop. And then an additional 16.09% are covered NLOS.
With information like this users can make valuable decisions (e.g. determining the benefit by changing the RAD center of the equipment).
Note: Migrated cnHeat 1.0 predictions will need to be re-run before this feature will work properly.
