i did raise ticket Request #337512
and it seems that cambium can’t bypass guest captive portal using same ssid. (wrokaround that was suggested was to use 2nd ssid… thats not an option)
this option is a must.
this option is needed to connect to network devices that are unable to authenticate by themself and are needed in same network. (like radio, weather station, some kind old device, device that doesn’t need to reauthenticate and etc.)
