Hello guys, i have a question here and need help. Is it possible to connect 450b to a point to point link(2 pmp 450b dish)
Yes, some if not most can be used for point to point as well as a PtMP client! You can find this out by examining the model number. The model number will depend on where in the world you are using the equipment. There are varying SKUs depending on the regulatory rules in which the radio will operate.
If the model number ends in “Bxxxx”, then it will operate in a Backhaul mode, rather than just as a CPE (which is “Cxxxx”).
