Cambium 4600c SFP+ Issue
Greetings, I have an epmp 4600c, I want to use sfp+, I use several transceivers without being able to turn on the interface, I tried 1gb and 10g tranceiver in different switch ports and combinations and it doesn’t turn on, I don’t know if it will be a problem or some kind of compatibility, I appreciate your quick help.
What SFP+ modules have you tried?
Thank you
We’ve used both Cambium and FS SFP+ modules in our e4k radios without issue. Fs Cisco compatible modules work with pretty much everything.
ALSO, I assume you’ve updated to the new 5.4.1 firmware?
