Hi
I just recently noticed that users connected to our Wifi are unable to download media files from whatsapp or playstore. Uploading via whatsapp works fine.
Any ideas?
Hi
Any ideas?
Why would you think that it is the AP that is limiting access to certain sites? Assuming that you’re using the 410 as a simple AP/bridge, it would be highly unlikely (if not altogether impossible) for it to do what you’re describing. You need to do more network troubleshooting and take things step by step and work your way through the network chain until you find out what is causing the disruption.
Unlock some rules on Palo Alto It is typical for this firewall vendor
