After connecting POE cable to LAN port of Cambium E410, red light is on steadily. I waited for a long time but green light is not on. Reset button is also not working during this time…please tell me the solution.
Could you please try pinging the Zero-Conf IP address (169.254.X.Y) of the device?
For reference, if the device’s MAC address is AA:BB:CC:DD:EE:FF, the corresponding Zero-Conf IP would be:
169.254.<EE in decimal>.<FF in decimal>
This will help verify basic Layer 3 connectivity when the device has not yet received a DHCP-assigned IP.
ys i pinged ur zero config ip address & also given me reply from zero config ip….
the device MAC(ESN) IS - BCE67C593AB0
Now whts the next step to boot up the device….
Could you please share the tech-support logs of the device before proceeding with the factory reset?
Once done, please follow the steps below to perform the reset:
Factory Reset Procedure:
Login to the device.
Capture the current software version by running the following command and share the output:
XV3-8-06B60C(config)# show version -
Perform a factory reset using the command:
XV3-8-06B60C(config)# delete config
Let us know once the reset is complete or if you face any issues.
